HamSphere 4.009 release
2015-06-24 09:36
Release 4.009 is now ready for download
We are building for the future with many exciting updates to the HS4 system. We recently released version 4.009 which was developed in stages from the 4.006 release.
This is what we have focused on
1. Improved data protocol.
Up to version 4.006 we have used the old 3.0 data protocol for audio and control transmission. The 3.0 protocol is as reliable as it gets, but we needed to be able to expand in many areas such as
* Support different codecs as well as CODEC OFF.
* Be able to achieve fast recovery when data packet loss occurs.
* Better buffer and latency control
Version 4.009 is now using a brand new data transmission protocol which gives us a more reliable connection.
2. External control of the HamSphere transceiver
One shortcoming of the 4.0 system has been "remote control". There has previously not been any way of remotely control the transceiver via neither native keyboard nor external communication ports such as USB etc.
Version 4.009 now has a new plugin called "Interface Adapter" which is a plugin that offers an intelligent interface between either keyboard or RS232 com ports. Finally we have the ability to control the HamSphere 4.0 transceiver via the standardized CAT (Computer Aided Tuning) interface.
3. Multiple transceiver setup
We have seen a big demand for multiple rig setup. Operators want to configure different transceivers for different situations such as DXing, SSTV work, ragchewing, VHF/UHF communications, small and big footprint transceivers etc.
Version 4.009 offers unlimited multiple rig creations using your purchased plugins and gadgets.
4. Codec Off
We use audio codecs to preserve bandwidth and to get lower latency. However encoded audio has its disadvantages. Digital and Analog SSTV operators usually dismiss audio codecs as these codecs distort and cut the audio spectrum making it impossible for digital audio transmissions. Therefore we have listened to the community and now offer a Codec OFF plugin which will enable the operator to bypass the audio codecs for a fully non-encoded audio stream.
Free Plug-in !!!
We are offering a brand new plugin called Mini Statistics. It is absolutely free for all 4.0.0.9 users and you can get the plug-in from the shop: http://shop.hamsphere.com
What have we updated / developed in the 4.009 release?
* Based on Java 7 update 80
* Better latency. Audio Round Trip Latency less than 300ms on faster connections
* PTT Delay improved drastically with almost immediate spike on scopes
* New data protocol with auto re-synchronisation upon packet loss.
* CW Keyer plugin
* Multiple transceiver templates
* Better international character set recognition
* Interface Adapter for Keyboard and RS232 Com port
* Broadcasters plugin with Advertising and Private messages + 1 kilowatt power amp.
* Waterfall mouse-wheel up / down
* Click on map in Grayline Map sets Azimuth.
* Bandscope mouse-wheel up / down
* Smeter LCD - New scale
* LCD - Now displays FM
* LCD Memory - Now displays FM
* BC Filter characteristics changed
* Power reduction to 5/15 watts on CW
* Realistic Bandscope display with 10 times faster updates
* Oscilloscope better response to local end remote activity
* Shortkeying improved.
* Shorter time for login screen message
* Logbook, ability to log 5/9 + 10 and RST retained
* Many sound freezes fixed
* Double click on azimuth in chat to set azi
* Chat renamed Dx Monitor
* Power Button 2 second time out
* Longer call sign box in log book
* Codec Off plugin
* Beacon audio better fluency
* SSH Poodle secured Version 2
* Several minor bugs fixed
New plug-ins
* New S-Meter Plus lit with illuminated background.
* Grayline map showing the sun/earth shadow. Now with AZIMUTH rotator setting by clickig on map
* BC Panel for broadcasters on the 48m BC band. Contains Advertising feature as well as PM feature. Contains 1kw amplifier.
* VU2NSB DX Antenna. Monoband DX antenna for 40m with high gain and great capture area.
* Codec Selector. Enables you to turn off the audio codecs and run straight uncoded audio for SSTV or BC.
* Mini Statistics - Free little useful plugin show some live statistics about your station.
* Micro Antenna Rotator control.For degree precision azimuth setting.
* Kenwood Skin based on the Kenwood TS-850 series look.
* VU2NSB DX Antenna. Monoband DX antenna for 80m with high gain and great capture area.
* Lookup Box. Easy to use database lookup tool for any call sign on the system.
* CW Keyer. Advanced CW Keyer with CW and Iambic mode. Speed, Tone and Delay settings. Keybord or Mouse controlled.
* S Meter Lit. The background lit version of the classic S-meter.
* BC Phased Array. Powerful antenna for 48m broadcasting. Has 23 dB gain.
* VU2NSB DX Antenna. Monoband DX antenna for 60m with high gain and great capture area.
* Interface Adapter. Assign any key to any function in your transceiver. Has a RS232 Com port driver built in for external control via CAT.
Upcoming contest
Welcome to the HamSphere 4th of July Contest 2015 HS4
Independence Day, commonly known as the Fourth of July, is a federal holiday in the United States commemorating the adoption of the Declaration of Independence on July 4, 1776, declaring independence from the Kingdom of Great Britain. Independence Day is the National Day of the United States
Will be held on HamSphere 4.0 bands 10, 12, 15, 17, 20, 30, 40, 60, 80 and 160m between 00:00 and 23:59 UTC July 4th, 2015, sign up in advance here:
http://hs4.hamsphere.com/contest.php?mode=edit&contest_id=284
Download 4.009
The 4.009 software is available for Windows, Mac or Linux: http://hs4.hamsphere.com/download
Lost your password?
Click here to get a new password: http://www.hamsphere.com/password
Join the HamSphere 4.0 facebook group
Follow HamSphere 4.0 on facebook
Thank you for your interest and your continued Support.
Re: HamSphere 4.009 release
2015-06-26 23:04
2015-06-27 01:14
Re HamSphere 4.009 release i need a test has i am new to the computer please install it for me it is the Ultimate Transceiver ,thanks for doing it for us
2015-06-27 01:17
2015-06-27 03:13
I do not know if hamsphere 4.009 can be operatede without site. do I need to uninstall any 0previous versions of hamsphere before installing the new version?
2015-06-27 05:55
У меня уже установлена HamSphere 4.009 прислали новый пароль swalew,но трансивер не открывается.Я с 10.06.2015. не мгу работать в программе.Причина не неизвестна. прошу помощь для дальнейшей работы в программе.Vitaly.
2015-06-27 07:05
will this work on the Imac
2015-06-27 07:54
Thank you very much Kelly,have upgraded to 4.0.0.9 and have some of the plugins mentioned above,all in all a very welcome upgrade and many thanks to you and your staff for their continuous effort and loyalty in providing an excellent Hamsphere 4.0.0.9.
Have a nice day to all of you.
Kind Regards
frank
43HS1688
2015-06-27 07:57
2015-06-27 09:34
No such call sign as I have sold my AR gear and retired.
Will continue to write scenarios for Razorback Railways. I am also building a 3D printer.
2015-06-27 10:08
donez moi la traduction....je ne parle pas anglais???cela m'interesse!!!
sorry I no longer have HamSphere on my pc
2015-06-27 10:48
The idea of such a configuration is OK. Component configurations are challenging for radio operator where he can confirm their knowledge and thus the success of the operation. We should let some time to give judgment on this radio operators and their experience wisely utilized. I think this is something that should be used with caution escort and smart place.
        YU5PMT
   Milos Stojkovic
2015-06-27 12:42
I AM PANKAJ M. JANI FROM MUMBAI INDIA ( VU3PMJ), I HAVE DEMONSTRATED TO MANY STUDENTS , HOW TO TALK ON AMATEUR RADIO AS PART OF AWARENESS OF HAM RADIO IN INDIA. THIS HAM RADIO COMMUNICATION HAD GIVEN VITAL HELP DURING DISASTER OF LATUR, GUJARAT,TUSUNAMI, KEDARNATH FLOOD AND NEPAL EARTH QUAKE 2015 AND PROVIDED NECESSARY INFORMATION TO THE AUTHORITIES, ALSO I AM HEAD QUARTER OFFICER WITH MUMBAI CIVIL DEFENCE AND ORGANIZING MOCK DRILL OF FIRE SAFETY AND RESCUE OPERATION IN MANY AREAS OF STATE OF MAHARASTRA, INDIA..
I APPRECIATE THIS NEW VERSION OF HAMSPHERE 4, WHERE I CAN ABLE TO IMPART MORE TECHNICAL KNOWLEDGE TO THE STUDENTS OF SCHOOLS AND COLLEGES. I AM NATURE & MUSIC LOVER AND RETIRED ALSO. BUT STILL I AM READY TO HELP SOCIETY TO IMPART THE KNOWLEDGE OF THIS RADIO. I AM VERY THANKFUL TO YOU FOR PROVIDING TIME TIME THIS INFORMATION.
THANKS & REGARDS,
PANKAJ M. JANI ( VU3PMJ)
EMAIL: pankajjani4u@yahoo.co.in
Contact No. 0091-09323190346
facebook id: 'PANKAJ MULVANTRAI JANI'
2015-06-27 14:32
Is there any likelihood of an iPad release please?
hello: I dont find yet a 4.0 version for Android.
2015-06-27 15:24
Excellent Hamsphere 4.009 Thank you Very Good ..._._ ..
2015-06-27 16:52
I need a test.
2015-06-27 16:54
I need a test. Thank you!!
2015-06-27 17:40
A version of Hamsphere 4.009 for the iPad would be good. I currently use Hamsphere on iPad. Absolutely BRILLIANT.
Malcolm. G1OZV
2015-06-27 18:55
Thanks a lot this version is superior, 73 de YU1NS
2015-06-27 19:38
I no longer have HamSphere on my pc as I am no longer interested in this programme.Therefore would you please remove me from your emailing list.
2015-06-27 20:06
Merci beaucoup cette version est super 73's de ON5IK
2015-06-27 23:01
I no longer have this call sign and don't have HamSphere on my computer. Please remove me from your mailing list.
2015-06-28 02:27
muito obrigado ! 73 / 51 31hs977
Kelley keep up the good work and keeping the whole world together, very nice program easy to use.
2015-06-28 08:38
Have moved to Ontario Canada and my new call sign is
Va3anq
My new address is
31 BayHill Ridge Stittsville On Canada K2S 1B9
Phil Pawsey
2015-06-28 08:44
This system of communication is one of the best I have ever used, as a amateur radio operator, when conditions are poor one can always get a contact somewhere in the world on Hamsphere,and for any one who is restricted to what they can use in the way of antennas what better way than using a computor to bring the world into your home. G0HMX
2015-06-28 22:20
Me gusta el sistema de comunicación de radio virtual,me a costado confeccionar la qsl para confirmar contactos.-Me gustaria probar en forma gratuita la nueva versi+on de HAMSphere 4,009.-Atte. cx8tb 12HS466.-
2015-06-29 06:05
Hello good morning to all radio amateurs there using the HamSphere 4009 program, I am quite happy with the program because it gives me the opportunity to use the 2 meters and 70 centimeters, although I would if I could use the six meters because every time I try transmit gives me many stationary or I get red, but in every way, I quite entertain, I hope to do here the same contacts I made in the HamSphere 3.0.
Thanks to all who have made this program
a greeting and a hug
manuel Vigario ea4ckc
